Hit 17lbs of boost is it normal
ZZP cams with the upgraded fuel lobe is all you need to run full E85 and actually benefit from it.
all you want is 300hp? that's easy. find a good tuner who uses HPTuners and you'll be set. a friend of mine hooked me up a while back with his winter tune from his Cobalt SS Turbo, it put down 300whp/362wtq on a DynoJet, that tune was VERY FUN. then i stupidily went to a 30psi tune and well.... i don't like talking about what happened.
if i was running meth injection, it would've been fine because of the additional cooling/fueling it provides.
just wasn't worth it on the stock turbo.
i am near the great lakes and have the stage 1 kit no tune other than that the most i can hit is 19 psi although today is very humid. As well just put in new cam actuators. The most I can remember is getting 20 to 21 which is what most have said is normal.
FYI, this thread is over 2 years old
