Hit 17lbs of boost is it normal
Old Jul 6, 2012 | 12:33 PM
rallycobalt06's Avatar
Originally Posted by Breadfan
This is my thinking also. By full E85, do you mean E47.5 or 100% E85 + higher flow fuel pump? I'm hoping for at least 300hp and a happy engine running E40 @ 22psi.
full E85 = 100%..... no mixes
ZZP cams with the upgraded fuel lobe is all you need to run full E85 and actually benefit from it.
all you want is 300hp? that's easy. find a good tuner who uses HPTuners and you'll be set. a friend of mine hooked me up a while back with his winter tune from his Cobalt SS Turbo, it put down 300whp/362wtq on a DynoJet, that tune was VERY FUN. then i stupidily went to a 30psi tune and well.... i don't like talking about what happened.
Originally Posted by foolmoon_design
Rally what was your experience, running it out of breath, or did the impeler start scraping?
over spinning the turbo, created a lot of hot boosted air, 2 pistons committed suicide.
if i was running meth injection, it would've been fine because of the additional cooling/fueling it provides.
just wasn't worth it on the stock turbo.
Old Sep 10, 2014 | 01:42 PM
cannuck's Avatar
i am near the great lakes and have the stage 1 kit no tune other than that the most i can hit is 19 psi although today is very humid. As well just put in new cam actuators. The most I can remember is getting 20 to 21 which is what most have said is normal.
Old Sep 10, 2014 | 05:49 PM
XtremeSS's Avatar
FYI, this thread is over 2 years old
turtizzle222
May 27, 2014 06:48 PM
XtremeSS
2.0L Performance Tech
13
Mar 8, 2010 10:48 PM
ouhockeyplayer
Dec 11, 2009 07:29 PM
Sandhog
Feb 25, 2009 12:14 AM
twistedamd
Jul 8, 2008 09:08 PM
