Ongoing saga advice or tips when replacing head
Old Aug 31, 2019 | 09:33 AM
Jit's Avatar
Jit
Good morning.
I had a brand new water installed and water pump has failed. It warped where bolts up to the block. It was repaced under warranty but nowalso leaks between head and block and they wont cover.
I bought a new complete ac delco head, gaskets and head bolts.
Any tips or advice when removing and installing the head? Ive done other cars in past.
Will be working on it next week.
Thanks in advance.
John
Old Aug 31, 2019 | 11:54 AM
Same carefulness, attention to detail as any other engine , there’s videos on YouTube to guide you thru .
https://www.google.ca/search?q=how+t...&client=safari
Old Aug 31, 2019 | 03:05 PM
Cat Man HHR's Avatar
Originally Posted by Jit
Good morning.
Wording is strange to me for a person that has done other mechanical repairs.
"brand new water installed and water pump has failed"
I could go on, but I won't.
Old Aug 31, 2019 | 04:32 PM
What was replaced under warranty? What won't "they" cover, why should"they"? What is a "brand new water"?
I would replace the timing chain and guides while I was in there.
Old Sep 2, 2019 | 10:42 PM
Jit's Avatar
Jit
Catman….I have restored over 49 vehicles in the last 60 years....btw thanks for the helpful advice...
Old Sep 2, 2019 | 10:44 PM
Jit's Avatar
Jit
Thanks Oldblue and Donbrew. I am going to do the timing chain as well. Have you had any experience with the Cloyes timing kit vs the AC Delco parts? Thanks again for your helpful advice.
Old Sep 2, 2019 | 10:48 PM
Jit's Avatar
Jit
The waterpump was installed at a GM specialist shop. It was and AC Delco replacement. The warranty replacement covered a new waterpump that was not part of the same batch that had warping problems. The warranty does not cover reinstallation of the new one or the head problem. However hard to know if the head gasket went first or the waterpump. Now I am going to do the work myself. That's what I get for not doing it the first time to ensure it all is done right....
Old Sep 3, 2019 | 07:14 AM
I’ve installed both brands of timing chain, the Cloyes come in a more complete kits
https://www.chevyhhr.net/forums/how-...in-kits-60394/
Mike's SS
29
Mar 23, 2021 03:04 PM
Jit
Oct 16, 2019 03:38 PM
Scouttster
Sep 22, 2017 04:39 PM
twistedjay
Maintenance and Upkeep
Nov 1, 2015 09:38 AM
RvBum
Jun 1, 2014 11:18 PM
