Powell Racing YYZ V.5 Lowering Springs - Install/Review
Old Feb 12, 2015 | 07:37 PM
XtremeSS's Avatar
Originally Posted by Oldblue
If they are touching they are binding as there is no movement allowed for spring compression. This would leave the upper coils to do all the work
Not sure if binding coils and dead coils can be considered the same. Either way, they are designed to touch like that. Best performance spring out there right now.
Old Feb 12, 2015 | 09:18 PM
prod's Avatar
Having some coils touching is ok, it's for negative compression, helps reduce the bouncing feeling.
Old Feb 13, 2015 | 01:22 PM
Negative? Compression, don't you mean no compression? If the coils touch they are binding or some callit dead coils either way it like a block or spacer and to open coils do all the flexing the shocks would control the bounce of compression and rebound .
Old Feb 13, 2015 | 05:16 PM
Told you they have a more civilized ride. They are fine on the auto cross track too........
Keep the rubber side down.........
Old Feb 13, 2015 | 07:57 PM
sinabu's Avatar
Yeah it's like a whole new car for sure. A longer commute today and I took the back roads home which were very rough on the old suspension. I remember being able to see my headlights bounce around in the distance while driving at night and now its nice and firm
So worth the money for these.
Old Feb 13, 2015 | 09:25 PM
  #26
prod's Avatar
What you say is true for most factory springs. Aftermarket lowering springs have to be stiffer so as to not bottom out. Adding progressive weaker coils reduces the bouncing feeling as the spring fully extends after a bump. Its hard to picture unless you see the suspension in full motion.
Old Feb 14, 2015 | 01:49 AM
  #27
XtremeSS's Avatar
I guess I just only considered binding coils to be coils that moved inside of another coil, not on top of.
Old Feb 14, 2015 | 08:37 AM
  #28
sinabu's Avatar
From my understanding. The coils are considered Dead and only rebound on larger bumps in which case they become active for that short time.etc. Binding would be the popping noise you hear when turning, It is catching on the other parts of suspension and twisting.
These coils so far have not been binding
Old Feb 14, 2015 | 08:42 AM
  #29
sinabu's Avatar
Heres a vid of binding coils
Old Feb 14, 2015 | 08:46 AM
  #30
Binding or hitting against each other is what my original rear Pedders did when I had them on my SS. Made for some clunking noises over any medium or larger bumps. Glad to get those off of my car.
Name:  Old Pedders rub spots.jpg
