Reduced eng performance
Old Apr 16, 2018 | 02:44 PM
I wish I knew a little more about that SS engine and the engine controls, and how the in-tank pump works with the High pressure fuel pump etc.. If anyone comes across an article on it, we should add it to the SS section if it isn't already noted somewhere here.
Old Apr 16, 2018 | 04:57 PM
I guess you could use a fuel pressure gauge and find out just how low?
Old Apr 16, 2018 | 05:14 PM
Thread moved to SS
Like this:
So it could be bad fuel injectors, any reason to suspect them? Maybe wiring to the fuel rail pressure sensor?
Old Apr 16, 2018 | 05:44 PM
So one of these?
http://www.rockauto.com/en/catalog/c...re+sensor,6376
Old Apr 16, 2018 | 05:48 PM
DrLoch's Avatar
donbrew you can read the tank fuel pump pressure ahead of the HPFP rail with a standard gage. HPFP pressure with a scanner or scanning program, ie hptuners VCM scanner.
Old Apr 16, 2018 | 05:51 PM
DrLoch's Avatar
Quick on the draw or keyboard OB. If the sensor is bad, I believe this ACDELCO 2134420 {#12614935, 12621292, 2134265} GM Original Equipment would be the one.
Need to read the intank pump pressure first.
Old Apr 23, 2018 | 04:57 PM
hhr06NJ's Avatar
twice for me same thing, a year apart, low power:
cleaned dirty throttle plate; fixed both times. 10 min repair
also, i wouldn't discount dirty battery terminals, and lug post on the fuse box - had other problems related to that too. Nobody cleans battery terminals anymore
Old Apr 24, 2018 | 12:46 PM
tjustice's Avatar
Turns out my trouble is the HP mechanical pump on engine, only 56k mi.
Old Apr 24, 2018 | 01:43 PM
Cat Man HHR's Avatar
How did you diagnose it to being the HPFP ?
Old Apr 27, 2018 | 04:53 PM
tjustice's Avatar
pressure from tank pump was 65-75 psi pressure @ fuel rail was only 600 psi ,would only turn 2k rpm , only time any body around here seen one go bad. my luck. TERRY
