Adding radio buttons on steering wheel
Old Jun 17, 2006 | 10:23 AM
  #91
1BadPig's Avatar
Guys, ahem, just take out the cruise control module, unplug the old, connect the new, and then reinstall like the radio switch. It's much easier and faster.
Old Jun 17, 2006 | 10:43 AM
  #92
MikeX's Avatar
You can do that sure, but it has nothing to do with getting the old harness out. That's what I'm referring to in my post, not connecting the plug.
Old Jun 17, 2006 | 01:20 PM
  #93
1BadPig's Avatar
The quote in your post was on the removal of the cruise control plug was PITA... I was just saying I removed the entire assembly to get it unplugged. I just re-read the post... you meant pulling the plug from under the bracket! Sorry.
Old Jun 17, 2006 | 04:22 PM
  #94
dnvachon's Avatar
Originally Posted by MikeX
If you don't want to keep the old connector, CUT IT!
Edit: It's in and working now, I love it. Neighbors probably wondering why I was honking my horn in the garage.
I warned ya!! The mute button is worth it all by itself.. I can push that button... yell out the window at the idiot that just cut me off then push it again and not hear a word they say back.
Old Jun 20, 2006 | 04:38 PM
  #95
ernie12b's Avatar
Just got the email i have been waiting for
just got this in email from www.GmPartsDirect.com
Part number 15234337 has been released off backorder with GM and is currently in trans-it to us from GM. As soon as we receive the part from GM your order will be shipped out promptly. We apologize for the delay of your order.
placed my order May 11, 2006
Old Jun 20, 2006 | 05:43 PM
  #96
HHRBruce's Avatar
I got the same message. Tracking # says 6/24 delivery!
Old Jun 20, 2006 | 09:00 PM
  #97
courthousedeb's Avatar
Just want to make sure these are the right part numbers before I order these parts. Can someone please confirm this, as I have seen several different numbers and since these are special order parts, I need to make sure they are correct. Thanks for your help.
Part Number 15234337 - Cover
Part Number 15234343 - Harness
Part Number 15842365 - Switch
Old Jun 20, 2006 | 09:40 PM
  #98
MCANAW's Avatar
This is the numbers I ordered. Got same message, be here Friday. Guess I'll be busy Sat. morning.
15234337 COVER
15234343 HARNESS
15842365 SWITCH
Old Jun 22, 2006 | 08:43 AM
  #99
thompy53's Avatar
This may be stupid to ask, but if I wanted to keep the horn quite during this, coundn't I just temp take out the horn fuse or relay?
Old Jun 22, 2006 | 08:49 AM
  #100
I believe that some people did not disconnect the battery, which would allow the horn to honk while working on this mod. As soon as I confirm that the parts above are the correct ones, I'll be ordering them and will disconnect the battery...just a safe thing to do in my books...but obviously not necessary. Plus...it should keep the horn from honking during install.
