Heated side mirrors conversion with pics
Old 10-09-2017, 10:33 AM
serch826's Avatar
I did my Heated side mirrors conversion very simple, bought two heated mirrors from this seller on Ebay:
CHEVROLET HHR 2005 - 2010 ASPHERICAL BLIND HEATED 12V MIRROR GLASS Left Side | eBay
Then i connected the mirrors wires with a 10 amp fuse on each to the fat "PPL" wire to the rear window defogger, situated on the driver side in the corner below the panel.
Drilled a small hole in the mirror from the side that is screwed to the door and placed the 2 wires with a female connector.
Then from the male connector those 2 wires in to the door and out to under panel.
Works perfectly, it is just to push the rear window´s defogger switch.
serch826 is offline
Old 10-09-2017, 11:46 AM
Cool! Er, that’s hot!
Oldblue is offline
Old 10-09-2017, 01:59 PM
serch826's Avatar
Thumbs up
Thanks!
serch826 is offline
Old 10-09-2017, 05:04 PM
Technical Moderator
Any chance you have pictures of removing the mirror? Or instructions at least.
donbrew is offline
Old 10-10-2017, 12:36 AM
serch826's Avatar
I didn´t it because there are many Youtube and other that explain this very well.
serch826 is offline
Old 11-08-2017, 10:32 AM
Cat Man HHR's Avatar
Here's a video for a 2003 Suburban. I'm going to say it's the same for the HHR.
The link he gave for the heated mirror only said for the left side. But he did left and right.
Also how did he run the right wires to the left kick panel area to tie into the purple rear defroster wire.
Heated mirrors would have been a nice option from GM.
Cat Man HHR is offline
Old 11-08-2017, 10:53 AM
Technical Moderator
Here is the wiring diagram, and why to not wire directly to the switch.
donbrew is offline
Old 11-08-2017, 12:58 PM
serch826's Avatar
Thumbs up
That´s correct!!!
serch826 is offline
Old 11-08-2017, 01:43 PM
I can see where you would have a "bang your head in the wall moment" if you did it any other way.
I do like those replacement full size spot mirrors.
$45 a hit is a shocker.
Old 08-15-2018, 05:21 AM
papa_jo's Avatar
I like heated mirrors in the mornings
papa_jo is offline
NxlKing2304
Mods - Exterior
59
12-07-2020 03:43 PM
Doctuh
05-11-2010 04:20 AM
joshua_arndt
12-01-2006 01:52 PM
O6ChevyHHR
10-08-2006 09:26 AM
Quick Reply: Heated side mirrors conversion with pics
