"How To" Tutorial LibraryWrite tips and instructions on how to install parts or fix problems. This is for detailed "How To's" only, not a forum to ask how to do something. Please post those questions in appropriate forums.
The new Moog bushing didn’t require a lot of pressure, I put the socket on it and tapped it into the LCA, then used the air chisel to drive it home , the vibrations did most of the work.
I’ve got a set of LCA’s here , I’ll make a video.
Explaination is harder without photos or videos.
I replaced the driver’s side bushing with solid AC Delco part using a press. Car now drives like new again. Biggest problem I had was the ball joint pinch bolt which was corroded in place. Ended up removing the three nuts holding the Moog ball joint to the control arm instead.
One important part to me and onewhich Heritage High Roof made a note to, is to get asolid bushing replace part and not thefactory type with the two holes molded in it. These just don’t seem to last aslong and really tear up bad, coming apart from the O.D. steel ring. Most manufacturesmake both types be it just the bushings or the complete replacement LCA arms. So Iwould check and make sure to get the solid bushing type. The bushing are affordable, the LCA, completeare big bucks… BUT it makes for a faster and easier job. If you get thecomplete LCA save the old ones and rebuild them for back-up later. …(or sendthem to me)… Really, I’m going to ask the dealer if I can have an old pair whenthey take the next ones off… Also a friend who has a garage. What have I got tolose in asking?
I now agree too that we need to check the LCA and not jump into thinking it has to be the brakes! Good point made....
I have to replace the LCA and found some with grease-able ball joints and this had me thinking which one do we use and which one is best for a given car. I found this to help with the question... but remember you should GREASE them every 3,000 miles or so, just remember this point.
