Sunroof quick fix (for those without warranty coverage)
Old May 25, 2010 | 09:27 PM
  #31
andoll83's Avatar
this is covered by warranty?
Old May 26, 2010 | 12:07 AM
  #32
Snoopy's Avatar
Not on an "06.......unless you have an "extended warranty". Generally if the repair is needed inside of the 36 month/36,000 mile bumper to bumper, it will be fixed.
Old May 26, 2010 | 05:59 AM
  #33
Originally Posted by zephyrHHR
ARGH! Mine just broke today, on the drivers side. Here is the catch, there were symptoms before it happend: The sun roof wouldn't close all the way without tripping the auto-reverse unless you kept pressing the close button. Did anyone else have a similar problem?
No warning signs of any kind given when mine just snapped upon opening.
Old May 26, 2010 | 06:52 AM
  #34
andoll83's Avatar
I have an extended warranty.... about 2k mikes left on it!
Old May 29, 2010 | 07:23 PM
  #35
Doctuh's Avatar
Used Wind Deflector
I am still looking for a used factory wind deflector or part. Mine broke off on the driver's side. So, either one that is fully intact, or one that broke on the passenger side, would allow me to be functional again after sunroof rail replacement repair (without having to buy a totally new deflector from Chevy). I plan to have the dealer do the TSB repair in July.
Old Jul 2, 2010 | 06:02 PM
  #36
Doctuh's Avatar
Does the fix work?
I just had mine fixed - but they only fixed the affected side, and left the other side alone. Has anyone had this fix done by the dealer and did they fix just one side, or both? Has anyone had the sunroof FAIL TWICE?
Old Dec 8, 2010 | 08:47 PM
  #37
kemmons's Avatar
Cool partial fix
My passenger side arm broke off so I followed the directions and took the screen off completely. THe problem is that the back part of the sunroof won't raise up enough to seal properly so I get leakage from the roof. Did anyone esle have that problem - any ideas? Help I live in Wyoming with the snow. Thanks
Old Apr 14, 2011 | 06:37 PM
  #38
Chrome_HHR's Avatar
You could also try to repair it. A bracket that holds the windscreen arm has a part number 20794829 and it costs $4.41 here:
http://www.autopartsdealer.com/gm_pe...1387499-g.html
The only problem is - the screws which hold it. The evil GM engineers put a one-of-a-kind screws there, with rounded holes and just a little notch on the side. Impossible to remove with a Phillips or hex screwdrivers. GRRR!
The other option is to find or manufacture a small metal hook and somehow attach it there so it will hold the windscreen arm.. My HHR has same problem and the dealer has quoted me $450. Ehm.. no thank you. I also noticed that a second bracket is just about to crack. Why, oh why, did they put PLASTIC parts there..
Old Apr 14, 2011 | 07:31 PM
  #39
Doctuh's Avatar
Screws?
The bracket that holds the windscreen arm, I thought, was held in by RIVETS. The detailed instructions in the TSB have pictures.
Old Apr 15, 2011 | 10:39 AM
  #40
Beachbum1's Avatar
I pulled my factory windscreen off and replaced it with a stick on plastic windscreen as shown in the how to section, which is where I got the idea. It works fine and eliminates some of the noise from the original
