Raked out
Old Apr 23, 2020 | 09:44 PM
Cory Flores's Avatar
Raked out
Hi everyone I bought a 2011 HHR LT. i love it. My only problem with it is, the rear end sits 2 inches higher then the front. Any suggestions? Pease and thank
Old Apr 23, 2020 | 09:59 PM
Cory- Welcome aboard & Congrats on the new ride.
You can change the rear coil springs to ones that will lower it. Easy to do. Check this: https://www.chevyhhr.net/forums/brak...ts-best-13137/
I leveled mine 10 years ago using now obsolete Cobalt SS/TC rear springs. Then after I added a TTR rear sway bar from one of our forum Suppliers here.
Old Apr 23, 2020 | 11:24 PM
Thanks man, I was also told to get beefier front lower control arms. And is there a rear disc brake coversion? I have a lot of questions.
Old Apr 24, 2020 | 08:02 AM
Welcome to the site, I’m looking into lowering spring options, I already have the TTR rear sway bar , a definite must have. I installed 2 inch lowering springs from a full set of Canuck Motorsports lowering springs, they were great , but I sold them and put the FE 3 springs back in, for now. More on that in a week or so.
The LCA’s should be aluminum, not stamped and riveted or welded steel, there are options , such as pressing out the old rubber bushings and installing nylon bushings and replacing the ball joints.
The rear disc brakes are either a salvage yard rear axle from an SS HHR or Cobalt , some have welded mounting plates for the rear calipers, some have mounting plates the bolt in to the rear axle hub mounting studs.
Our search window will open up many threads in these and many more subjects.
Old Apr 24, 2020 | 09:41 PM
DwRed2LT's Avatar
Welcome and Congrats on the '11 HHR LT.....!
Old Apr 25, 2020 | 09:28 PM
Cory- Yes, perhaps best route is from a bone yard off a Cobalt SS or HHR SS rear axle complete. Get everything. Nice up-grade.
Old Apr 26, 2020 | 08:20 AM
Including the E brake cables
Old Apr 26, 2020 | 08:40 PM
Yep....
EVO3
Dec 22, 2017 10:03 PM
retrolled
Sep 12, 2013 11:40 PM
Joshua022
79
Nov 4, 2012 10:50 PM
88hhr
Oct 19, 2011 12:28 PM
Marcruger
64
Nov 9, 2010 05:46 PM
