Getting ready to do the timing chain change with water pump on my 2011 2.2.
I have looked here for a possible list of gaskets needed, but haven't found one.
I just wanted to make sure I had everything needed for the task.
Will most likely order the Cloyes timing set from RA
Is there a gasket list here or does anyone have one?
Valve cover gasket GM 12598014
Engine front cover gasket GM 24435052
water pump gasket set Victor Reinz 181007101 includes
thermostat housing gasket
AC Delco 131-158 thermostat
Cloyes 9-4201SAWP timing chain and water pump set
That should do it, anybody have anything else let me know and I’ll add it here .
I strongly recommend GM gaskets as I had leaking problems with FelPro gaskets and crankshaft seals few years ago
I had the same experience as Oldblue.
DO NOT USE a Felpro front cover gasket.
The one I installed, leaked and had to be changed.
On the good side..........
I knew how
Thanks guys.
I'll check Rock Auto for those part numbers
Just wondering if that list includes the large orings for the tube from the water pump to the tstat housing?
And the upgraded guide.
Is the upgraded guide included in the Cloyes kit?
I'm guessing a new crank seal would be wise while the cover is off?
