Sunroof closing issues
Old Aug 31, 2023 | 02:05 PM
flstss's Avatar
My wife's HHR had a problem closing the sunroof, it got stuck open I was able to get a closed. But the passenger side rear corner was up too high when it was closed. I did some searches and there was a way to adjust the height which I tried, it did come down a bit but I thought there had to be something else wrong.
After further inspection I see on the passenger side there is a piece of plastic that broke off of the mechanism. You will see in the pictures I post. Is there a fix for this or does it have to be replaced? If it needs to be replaced is the parts still available and what would it be called or part number would be helpful. So when the roof is closed from the inside I can push up on the rear corner of the sunroof on the passenger side. On the driver side it doesn't budge so that's the issue that broken piece in the picture. Thanks Scott
This is the driver side good bracket
Passenger side
Sorry about the sun glare but this is the broken bracket. You can see it's out of the grove
Driver side
Old Aug 31, 2023 | 05:05 PM
https://www.chevyhhr.net/forums/how-...dollars-59404/
Are good tutorials
Old Aug 31, 2023 | 06:12 PM
flstss's Avatar
I looked at that, already thanks. But that's not the problem this is where the back of the sunroof goes up into vent. It's the little arm that pulls the sunroof down when you hit the button to close it. It's not the vent in front or anything to do with that.
Old Aug 31, 2023 | 06:13 PM
flstss's Avatar
Meant to say air deflector in front. Nothing is wrong with that whatsoever
Old Aug 31, 2023 | 08:09 PM
I'm pretty sure that individual parts are not available.
Old Aug 31, 2023 | 09:46 PM
And never were, new.
Old Sep 1, 2023 | 12:28 AM
Lonwane's Avatar
I ended up finding used sunroof from an auto recycling yard.
Used the donor vehicle to learn how to do the job.
It took several hours to change out as I did it by myself.
Old Sep 1, 2023 | 08:13 AM
These guys might have parts
https://sunroofexpressparts.com/chev...unroof-express
Reach out to them
mongo
Jun 18, 2023 12:18 AM
OKIE SS
Oct 23, 2021 05:08 PM
ULOS2A6
"How To" Tutorial Library
Feb 21, 2021 08:51 PM
AJL08SS
Jun 16, 2014 10:18 AM
holmesdude
Jan 31, 2012 10:16 AM
