Mods - Interior Discussion related to the looks of the interior of the HHR.
Adding a voltmeter
Old Sep 3, 2014 | 11:47 AM
Kookie. I don't believe our cars have an internal regulator in the alternator. The service manual will even refer to what we call the alternator, as a generator.
I'm pretty sure the voltage output is controlled thru one of the computers. Just don't recall if it's the BCM or ECM maybe.
Old Sep 3, 2014 | 12:21 PM
db/sb's Avatar
The HHR does have an internally regulated alternator. Regardless of what GM calls it, it is an alternator with a rotor, a stator, and a rectifier bridge; items you wouldn't find in a generator.
File Type: bmp
Old Sep 3, 2014 | 02:29 PM
Thanks db/sb for clarifying that.
Old Sep 5, 2014 | 09:52 AM
Kookie's Avatar
Yeah, thats what I thought. So, a 13.2v - 15.4v output, is that usual / typical?
Old Sep 5, 2014 | 04:01 PM
15.4v is high - it should peak in the mid 14.x's
Old Sep 5, 2014 | 04:25 PM
  #26
Kookie's Avatar
I thought so. I think there might be something wrong with that alternator. Thats why I installed the voltmeter. To keep an eye on it. But I just can't put my finger on what really might be wrong. Time will tell no doubt.
Old Sep 5, 2014 | 04:30 PM
  #27
Funny thing whopper. The repair manual says with the engine off, voltage should be 12.6-15.0 volts.
Just scanning thru some of the repair testing, I see references to voltages ranging from 5-26 volts.
These modern day automotive electronics sure have gotten complicated.
Old Sep 9, 2014 | 10:27 AM
  #28
HHRNole's Avatar
Instead of a single gauge I got a Scan Gauge II and mounted it over the airbag light. Besides being able to monitor my voltage, I can read things like MPG,intake temp,throttle position sensor,coolant temp. and the list goes on. Also if I have a code that comes up ,I can read it and clear it also.
Old Feb 24, 2015 | 10:41 PM
  #29
thunder94's Avatar
Nice, would look cool in the pocket under the radio IMO.
MurderMittenSS
Mar 12, 2017 10:37 PM
bulldawg449
Mods - Exterior
Aug 9, 2012 03:23 AM
asanti
Sep 10, 2009 06:19 PM
Dremin2flyhi
May 23, 2008 12:03 PM
FXM
May 22, 2007 12:25 PM
