2 Blown Headlights.... Help!
Gloves or not, odds are you got something on the new bulb prior to installation. I'd try a new bulb and go from there. Get the splash shield as much out of the way as you can. That will give you good access to the bulb opening.
Moisture will do it too. Check the headlight housing at different times of the day when the headlights are not in use. Early morning say when the dew point is happening, etc. All it takes is a little wetness..... Check for moisture beads on the inside of the housing.
