2 Blown Headlights.... Help!
Old Jun 20, 2011 | 10:13 AM
LawDog88's Avatar
Mike,
Mine is over 50,000, and I just take it in for oil changes, and say "hey, while you are at it, can you check this out" most of the time they just do it and not worry about it.
Old Jun 20, 2011 | 12:58 PM
solman98's Avatar
Gloves or not, odds are you got something on the new bulb prior to installation. I'd try a new bulb and go from there. Get the splash shield as much out of the way as you can. That will give you good access to the bulb opening.
Old Jun 20, 2011 | 01:02 PM
LawDog88's Avatar
Personally, I would try removing the bumper and having full access, see if that makes any difference.
Old Jun 20, 2011 | 01:11 PM
It's even possible there was something on the bulb when you bought it..... Clean the new one as previously mentioned.
So you recommend bumper removal every time someone needs to change headlight bulbs???? That will go over really well.
Old Jun 20, 2011 | 01:31 PM
ChevyMgr's Avatar
Really???
Old Jun 20, 2011 | 01:38 PM
LawDog88's Avatar
No, I am saying to try it that way this time, instead of trying to arm it into place.. It may make some difference.
Old Jun 20, 2011 | 01:40 PM
nacademus's Avatar
Originally Posted by ChevyMgr
Really???
Personally... I would just drive during the day.
PROBLEM SOLVED! LIKE SOCKS ON A CHICKEN BABY!!!
Old Jun 20, 2011 | 09:18 PM
BlackknighT's Avatar
Moisture will do it too. Check the headlight housing at different times of the day when the headlights are not in use. Early morning say when the dew point is happening, etc. All it takes is a little wetness..... Check for moisture beads on the inside of the housing.
jellis
Sep 14, 2012 11:01 PM
Crazy Canuck
13
Sep 10, 2010 09:38 AM
Pumpkin
Aug 26, 2008 05:39 PM
NORCAL SS
May 18, 2007 03:02 PM
HHR Forever
Oct 25, 2006 03:56 PM
