2006 chevy hhr 2.2 ecotec
Old Sep 19, 2017 | 08:56 PM
Coles 69 elky's Avatar
Thx I have the part but this is not what my motor looks like. Odd I know...
Old Sep 19, 2017 | 09:00 PM
Thank you all for the info. I put everything back together with no luck as to where the sensor would go. Since the car is having starting issues I'm going to replace the starter. It makes a weird noise as if the starter is spinning and not engaging. Will update as I go. Will also try and get those codes.
Old Sep 19, 2017 | 09:36 PM
When you have the starter out, have a look at the ring gear on the flexplate. See if the teeth are damaged or missing. Maybe there's an inspection cover you can remove and get a better look.
Old Sep 19, 2017 | 10:03 PM
Did I waste my time with post #7?
Old Sep 19, 2017 | 10:12 PM
I will be sure to do so
Old Sep 19, 2017 | 10:14 PM
no time wasted my friend I still need to get those codes cuz the sensor still needs replaced. Whatever the code maybe. I will let you know thx
Old Sep 19, 2017 | 10:25 PM
What part of "The 2006 2.2L does not have camshaft position sensors" are you not understanding?
I even attached a technical description of the system!
Old Sep 20, 2017 | 12:59 AM
Wait, this started as a no start condition - and after numerous questions/suggestions and more questions, we NOW hear that the starter spins, but it doesn't sound like it's flippin engaging?
I'm sorry, but I'm out on this one. I do not have the patience for a game of 20 questions.
Old Sep 20, 2017 | 01:07 AM
Holy cow I didn't see the information you posted. I will have to get the codes to find out what is being called out on the check engine light. Obviously gm didn't program there crap right. Sorry for wasting any of your time.
Old Sep 20, 2017 | 01:08 AM
I don't want to play 20 questions either. Like I said I'm going to replace the starter. Download any codes and go from there like all of you have said. Anyway thanks for your help.
GDZHHR
2.4L Performance Tech
20
Feb 25, 2009 09:20 PM
HHRDK
Racing Discussion
May 3, 2008 01:59 PM
Lone Ranger
Aug 4, 2007 09:29 AM
