2006 Engine compatible with a 2008
Old Apr 6, 2015 | 09:38 PM
JerseyJames's Avatar
Post
valve covers, just for comparison ...
No VVT . . . w/o spark plug/coil
Yes VVT . . . with spark plug/coil & (2) VVT solenoids
w/o spark plug/coil and no VVT solenoids
Old Apr 6, 2015 | 11:36 PM
Ijazzu's Avatar
THANK YOU.....JERSEYJAMES: You put it out there!
GREAT POST! I think you showed the Original Poster what he needed to know.
I think he needs to find out if he can add the VVT to his car. I know that there are kits for V8, but I'm not sure if they offer it for 4 cylinders.
Old Feb 26, 2020 | 03:33 PM
Chrishhrdude's Avatar
Are The valve cover with the VVT shown in the pictures above are from a 2006 hhr 2.2 ltr engine? I was going to put my 2008 2.2 ltr hhr cylinder head on an 2006 2.2 ltr engine. But you guys are saying it won’t work because of the VVT sensors.
thank u
Old Feb 26, 2020 | 03:46 PM
Cat Man HHR's Avatar
The 2008 VVT head has oil passages so the solenoids will work with VVT (Variable Valve Timing).
The 2006 wasn't made like that.
You could use the 2006 valve cover on the newer head style but you would have to block off the oil passages in the newer head.
Or possibly use the newer head with solenoids in place along with the newer valve cover. Don't really know, just a shot in the dark with this.
Get the correct head for your application.
Old Feb 26, 2020 | 04:30 PM
They are entirely different engines, the only similarity is they are 4 cylinder DOHC. 2006 2.2L and 2006 2.4L and 2009 onward 2.2L that is.
Old Feb 26, 2020 | 06:11 PM
I believe the 2009 2.2 was the start of the VVT , all 2.4 and 2.0 have VVT
So, if your 2008 2.2 head is non VVT , it should bolt right on
Ok
kills my idea of putting the 2008 2.2 ltr cylinder head on top of the 2006 2.2 ltr engine block... better to know now than try it and realize it was a waste of time.
Old Feb 26, 2020 | 06:13 PM
Take a picture of both heads and post them , we’ll verify it for you.
Old Feb 26, 2020 | 10:30 PM
You might try comparing part numbers. Lots of online GM stores to choose from.
Jason Walker
Jul 28, 2018 06:12 AM
cpirrmann
Jul 8, 2018 09:50 PM
wardfamily1
Oct 24, 2017 11:07 PM
DeVaughn
Oct 1, 2017 07:52 PM
squik
Mar 3, 2016 12:35 PM
