2006 water pump replacement nightmare
Old Sep 26, 2021 | 10:00 PM
UnknownError's Avatar
I had this whine when I changed my water pump too. The tensioner on that chain has to be reset to get the whine to go away. It should be fine for quite a while but be aware that if you haven't had the timing chain changed recently then when you do you may have to replace the pump again at the same time.
Old Sep 26, 2021 | 11:31 PM
geg's Avatar
geg
x2 .
Old Sep 27, 2021 | 08:36 AM
Az2021's Avatar
Ok I drove it temp holds steady at 187 the noise comes and goes a vacuum hose was broke and I'm go in to a friend's shop today or tomorrow. Thanks all for helping :)
Old Sep 27, 2021 | 09:43 AM
Please keep us updated!
Old Sep 30, 2021 | 01:15 PM
Az2021's Avatar
Ok update after water pump install car ran but it was rough a friend discovered a broken or severed vacuum hose. Nest day I see check charging system then felt it dying cause I was losing power steering. Been waiting on my ex to fix it and today noticed broken belt hanging underneath.
I will update when I learn which belt it is
Old Sep 30, 2021 | 01:29 PM
From our commonly used part thread: 2006 uses Dayco 5050400
Old Sep 30, 2021 | 02:36 PM
There’s only the serpentine drive belt for the alternator and AC compressor, possibly the tensioner pulley seized. There are 2 possible belts depending on the AC compressor clutch . Read throughly the 2006 listing in the RockAuto page previously posted.
Old Oct 1, 2021 | 11:39 PM
Az2021's Avatar
Update
After being stranded for a week or should I say another week my ex finally showed to fix the belt so I thought....he says air compressor ceased causing belt to break. So I'm gonna be stuck one more day.
At least my windows are rolled up and I can lock my doors now.
Someone stole my clothes and my dead sisters make up case today. It's been a rough week. I just wanna get back to work and out of this parking lot.
Old Oct 2, 2021 | 12:36 AM
Thanks for the update, let us know how it goes!
donbrew
"How To" Tutorial Library
17
Sep 8, 2022 11:44 AM
Hot Bite
Jan 1, 2019 11:32 AM
geezer
Dec 29, 2018 06:46 PM
donbrew
Jan 21, 2013 08:00 PM
River
Sep 28, 2009 07:39 PM
