2007 HHR Won't Crank/Start & No Fuel Pump
Old Apr 21, 2018 | 02:41 PM
Bpopilek's Avatar
Originally Posted by donbrew
What about fuse #10 on the BCM?
What was going on just before this started?
How do you know the fuel pump is not running? It only runs for a few seconds if the engine is not running.
Fuse 10 and all of the other fuses in the BCM test fine. I replaced fuse 10 just to be certain as well.
The fuel pump should prime for a second when I turn the key on and it is not priming at all. I cannot hear it engage. It is audible when I manually turn it on from the fuse panel.
I called my sister to find out if there were any problems that she didn't mention to me before. She said that prior to this it ran fine and nothing indicated there was a problem starting to occur. With the exception of the starter being slow and starting to die.
I did just find out that she had her friend use a cheap code scanner before I got involved and he cleared out a code. She called him and he said that he thinks it was a P1682 code. I have not seen that code with my scanner, nor do I get any codes from it.
Old Apr 21, 2018 | 02:43 PM
Did you check recall status yourself, or are you just trusting what you were told by the used car salesperson?
Old Apr 21, 2018 | 02:45 PM
Bpopilek's Avatar
I'm going by what I was told by my sister. I can verify that myself
Old Apr 21, 2018 | 02:50 PM
You should, that P1682 is an ignition switch code.
Old Apr 21, 2018 | 03:00 PM
The theft deterrent would only turn the fuel pump off. The starter would still work.
Did the car formerly have an after market security system?
A buy here pay here immobilizer?
What happens if you apply 12V to the solenoid? The purple wire.
Old Apr 21, 2018 | 03:01 PM
Then there's this https://www.chevyhhr.net/forums/prob...s-56913/page2/
The fix was a new battery. See if someone will test it and give you a printout that you can post up here.
Old Apr 21, 2018 | 03:09 PM
#7 and #8 are both listed as "Transmission Safety Starting Switch", so be sure to check them both.
One is the brake pedal position sensor.
Did some bozo jump start the car and touch the ECM with a hot cable?
P1682 would involve the power train relay and fuse.
What about turning the key to ACC, any radio?
Old Apr 21, 2018 | 03:25 PM
There are 2 more switches on the brake pedal.
Old Apr 21, 2018 | 03:36 PM
We my be getting somewhere; P1682 is saying that ignition 1 is a) shorting to ground or open at the power train relay and/or b)open at the run/crank relay.
That would be fuse #48 under hood.
Old Apr 21, 2018 | 03:57 PM
Something odd, regarding OP point #8, the owner manual shows underhood fuse #62 is Instrument Panel, Ignition. But the wiring diagram I have for 2007 and earlier shows the HVAC/ I/P IGN fuse 10A is in the BCM. Which seems to be fuse #16.
It also says it is hot w/run/crank relay energized, so I agree don. OP point #2 may be the issue.
This fuse #16 in the BCM is needed for the clutch start switch, which looks like is needed for the crank relay. The fuse is also needed for power distribution. Has BCM fuse #16 been checked?
