2007 HHR Won't Crank/Start & No Fuel Pump
Old Apr 22, 2018 | 05:55 PM
  #31
Ignition 1 does not connect to the key switch. It is a wire that will immobilize the vehicle. Usually an immobilizer will be installed by cutting one of the ignition 1 wires and splice wires from the module on each part. There are 2 ignition 1 wires next to each other on the BCM.
Is this your repair?
Old Apr 22, 2018 | 06:00 PM
  #32
Originally Posted by donbrew
Why an after market remote start was installed is a question, it should be factory installed. Look for AP3 on the glovebox door, or wires leading to the hood latch.
It's a manual trans.
Old Apr 22, 2018 | 06:06 PM
  #33
Bpopilek's Avatar
I had to leave to go run errands but can check more by the BCM when I get back later tonight. Do you know where both parts of ignition 1 are at the BCM so I can trace those both back? It's possible something else is hidden further back in the center console that I cannot see.
Old Apr 22, 2018 | 06:11 PM
  #34
Bpopilek's Avatar
No that is not my repair. I believe the photo makes it look like a splice job, but there was a power wire connected from that spot to the dball module. It is just cut and I haven't fully cleaned it up yet.
Old Apr 22, 2018 | 06:16 PM
  #35
That is a splice the aforementioned immobilizer. It is one of the ignition 1 wires, sound familiar?
Old Apr 23, 2018 | 09:07 AM
  #36
Here is the generic directions for installing RS and alarms.
Directed Support - Installing Your DIY Security and Remote Start System
Here is a pictorial of a Cobalt install, should be similar.
https://www.the12volt.com/installbay...asp?tid=138634
And HHR
https://www.the12volt.com/installbay...asp?tid=131309
Old Apr 23, 2018 | 10:41 AM
  #37
OK. Trying to keep it simple and taking a wild guess here.
Does anyone else think "A" looks corroded ? I would also check "B".
I know I've read several posts in the past of owners tracing down electrical gremlins. Then they find it was simply a bad battery cable connection at the fuse box.
Old Apr 23, 2018 | 10:47 AM
  #38
B is the power steering
Old Apr 23, 2018 | 04:30 PM
  #39
Bpopilek's Avatar
Everything at both terminals was cleaned and I removed all corrosion. I have looked again and there aren't any modules left in the car that could be interfering with ignition 1. Is there a way that I can try jumping in power to enable everything that isn't receiving power?
Old Apr 23, 2018 | 05:00 PM
  #40
Have you checked for 12 V on the large red/blk wire on the upper left of the BCM?
check your PM
