ABS kicking in when it shouldn't
Old Aug 22, 2014 | 06:10 PM
canroc's Avatar
Tech ii tool found no codes. The abs kicks in at low and high speed stops. I want to disconnect the abs temporarily.
Old Aug 22, 2014 | 06:28 PM
Sorry that is not legal to do or to discuss here, if it is possible.
Most likely you have a bad hub and just can't hear it yet, or a brake that is not engaging. That is where your diagnosing should centered. Has anyone ever checked the rear brakes, or adjusted them?
The only inputs to the ABS system are the wheel speed sensors.
Old Aug 22, 2014 | 08:26 PM
Any chance you have mismatched tire/wheel sizes on the car that trigger the miss-matched speed readings?
Old Sep 16, 2014 | 08:36 PM
canroc's Avatar
I disconnected the ABS and took the car for a spin. The behaviour went away so I know for sure this is ABS kicking in. Reconnnected the ABS and it is back. Now I need to isolate, but difficult with no codes.
Again.. the ABS kicks in randomly and only for a split second. There seems to be no rhyme nor reason to it.. i.e. happens at any speed when braking, at a hard brake or soft brake, and very random, maybe 10% of the time I brake.
The tires are all the same. The brakes are fine. Maybe a bad bearing, maybe a bad speed sensor, maybe a bad wiring harness. This will take some time in troubleshooting. Since it is probably a Chevy issue rather than HHR issue I will scour the Chevy forums looking for an answer. No one here seems to have experienced this.
When I get it fixed, I'll update this thread.
Old Sep 17, 2014 | 05:04 AM
Lucky's Avatar
With the tech two hooked up and looking at the wheel speed sensors, drive the car slow to a stop and you will see one of the wheel speed sensors go to 0 speed when all the others show some speed.
The one that go's to 0 too early is the one that's causing you problem.
Old Sep 17, 2014 | 06:11 AM
The real way to diagnose is to pay someone that knows what they are doing. They need to read live data while the car is being driven. A good scantool (like Snap-On sells) can do the job tech2 not required. The guys I have asked said about $75.
You could just replace all 4 hubs.
IF the ABS and/or ESC light is on there will be codes, apparently ours don't store them.
Old Sep 17, 2014 | 05:01 PM
Mine is still working great....the steering angle sensor also reports, along with the speed sensors. The code to check it took a tech 2 to read it, the snap-on computer didn't see it.
Old Sep 18, 2014 | 06:25 AM
Strange, my guy used his Snap-On scantool to read mine. They need a special set of "keys" to plug into the OBD port to get into it.
SS has a different system, BTW.
Old Sep 18, 2014 | 04:29 PM
Hey that's good news, perhaps I won't have to go through it twice. It was this one scaring the pants off me......
camaro98z28
Jun 23, 2017 02:32 PM
843de
May 26, 2011 09:30 PM
hurst2001
Aug 10, 2010 09:29 PM
dchris1918
2.0L Performance Tech
22
Aug 25, 2009 06:57 PM
