AC Quit Working Today
Old Aug 3, 2011 | 12:53 AM
I'll second Lucky here, take a quick trip to a parts store to check for codes and have them cleared, the BCM might have become confused for some unknown reason. It also controls the engagement of the clutch on the compressor, since every time you punch the button for the A/C it actually sends an electronic "request" for clutch engagement and cycling.
Old Aug 3, 2011 | 05:21 AM
chula52.1's Avatar
got to a good shop and have them check the ac temp sensor. Its a realtively cheap ac fix, around $180.
Old Aug 3, 2011 | 09:31 PM
BlackknighT's Avatar
Originally Posted by Lucky
I wounder if something just got freaked out by turning the a/c off and on Im not sure about the hhr but on some gm cars if there is a fault code in the pcm for the a/c system the a/c will not work untill the code is cleared. might want to make a trip to the part store and have the codes read or unhook the battery for a few min.
Yes there are codes but don't know if they show under regular ODBII scanners or under a Tech.
Old Aug 4, 2011 | 12:14 AM
Sidecardog1's Avatar
I am assuming that your fan is in an on position and working? If not the A/C won't run. If the fan won't run at any of the speeds, check the fuse for the fan. No fan, no A/C. I panicked one hot day when I inadvertantly turned the fan speed dial to off and nothing was happening with the A/C indicator light when I hit the button until I realized my mistake with the fan!
Old Aug 4, 2011 | 12:39 AM
How's the thermostat ? Someone here had one stuck open & it would not let the A/C work..
Sounds strange, but true..
jdavid
Nov 11, 2014 06:09 AM
CarlsSS
Nov 19, 2011 01:42 AM
pjtshhr
Jan 31, 2011 07:48 PM
dav68camaro
Sep 4, 2010 11:54 PM
denny
Dec 31, 2008 12:48 PM
