Brake noise
Old Oct 12, 2022 | 03:39 PM
WilliamKirkland's Avatar
Brake noise
Both rear wheel bearings replaced, rear drum/front disk 2006 HHR LT...occassionally when braking in light traffic there is now a noise from the front left..the steering wheel shakes occassionally? What's up??
Old Oct 12, 2022 | 04:02 PM
Something is wrong.
Old Oct 12, 2022 | 06:12 PM
Possibility the brake wear indicator isn’t installed correctly, could be the backing plate splash shield is touching the rotor, or the brake pad clips are touching the rotor. It could be tge caliper bracket bolts aren’t properly torqued .
Tgen there the possibility of the rear bushings in the LCA’s are worn out, causing a shake when you brake
Old Oct 14, 2022 | 09:06 AM
PulpFriction's Avatar
I don’t like replacing OEM disk. Garages sometimes falsely believe they must be turned or replaced, and don’t like the extra time if they don’t have a lath. Cheap replacements may. Also, ceramic pads are quiet but cost more. If you don’t specify ceramic pads, you may not get them.
WilliamKirkland
Sep 6, 2022 08:25 PM
HHRnovice
Jun 23, 2022 12:34 AM
hans317
Mar 14, 2013 10:13 AM
Cajun
Jun 13, 2008 12:46 AM
xzombiex66
Mar 7, 2007 01:20 PM
