Brake pads & squeaking question..
Old Aug 9, 2015 | 05:35 PM
hhrumadbruh's Avatar
I hear them squeeking. How bad can I mess them up if I don't change them? Can I just get the cheapest $25 pads?
Last edited by 843de; Aug 9, 2015 at 06:01 PM. Reason: More descriptive thread title....
Old Aug 9, 2015 | 06:00 PM
If they're squeaking, then you're probably down to the wear indicators which are designed to squeak, squeal, and make a general fuss when the pads are worn out.
So messing up the pads is of little concern, they're knackered, but you can score the rotors eventually leading to a bigger bill when you have the front brakes done.
If you haven't done your own brake work before, or it's something that you're unsure of, get your HHR to a reputable brake shop tomorrow.
Old Aug 11, 2015 | 11:16 PM
Changed them and it was super easy :) Never changed pads before.
The only issue I saw was the rubber around the cylinder was bubbling up a bit when we compressed the cylinder to get the new pads on. Is this normal? Seems to be fine now after driving over 200 miles.
Old Aug 12, 2015 | 06:18 AM
Not sure what "bubbling" means, but the rubber is accordioned so that it can expand and contract. It should not be wet.
Old Aug 12, 2015 | 07:18 AM
My driver's side dust boot, has a bubble it's been fine for 5 years now.
mmace311
17
Mar 28, 2013 12:29 PM
JAXFL_SS
Jul 5, 2010 11:26 PM
bad03xtreme
Sep 18, 2009 11:17 AM
tjm
0
Sep 8, 2009 02:45 PM
Red5spdSS
10
Jan 13, 2009 12:42 PM
