A/C broken
Old Sep 21, 2016 | 09:31 AM
I had this issue it was the blend door, just saying.
Old Sep 21, 2016 | 10:42 AM
Could very well be that he has a blend door problem also Oldblue. Not unheard of to have more than 1 thing wrong when you have an AC problem.
Going back to the original post of high compressor head pressure, then the fact that the cooling fan isn't working, I think these have to be addressed 1st.
Old Sep 21, 2016 | 10:47 AM
James Jacobs's Avatar
Originally Posted by donbrew
Bingo! The radiator cooling fan is the gremlin.
At this point you need to know which model you are working on because the fans are different. Can I assume that you can tell if the car has a turbo? That would make it an SS, with different parts from a LS/LT.
Oh yeah , I know I sound like a newbie or " Greenhorn " as we were called in the day . But I've actually been wrenching since I was a kid ( now a 50 yr old kid lol !) no it's not an ss ( no turbo ) , Is there a certain procedure on this particular vehicle for testing the fan to see why it's not coming on in a/c mode ?. Btw I didn't know that the fan was actuated when in a/c mode , learned something there , Thanks .
Old Sep 21, 2016 | 10:51 AM
Also , I checked the fuses under the hood and they appear fine .
Old Sep 21, 2016 | 12:18 PM
The test is to hotwire the fan, or just check for power with a VOM.
The A/C is on when in defrost mode with no indicator light, also when in recirc mode, or when the A/C button is pressed. That's why winter MPG is lower.
The radiator fan is always on when the A/C is on.
If the radiator fan is not on when the compressor is running the refrigerant will not get cooled down, causing trouble.
I think the 2006 has a fan relay.
breynol
Oct 10, 2015 12:50 AM
Jun 11, 2012 04:56 AM
Firewatcher
Feb 19, 2009 09:53 AM
GDZHHR
Jun 23, 2007 05:59 PM
dbarberaz
May 4, 2006 09:44 PM
