Car will not stay running
Old Aug 3, 2017 | 05:23 AM
Cena's Avatar
Originally Posted by SuKi
Seriously though, a code reader is good to have, and as previously stated they are inexpensive. Someone said less than $100, but many are less than forty. And by the sound of your previous maintenance and repairs, you have the capability to fix this once you find out what it is.
yes, i think your right. It would be a wise investment.
Old Aug 3, 2017 | 10:40 AM
This is the one I've got, no problems with it. $22 on Amazon.
https://www.amazon.com/BAFX-Products-34t5-Bluetooth-Android/dp/B005NLQAHS https://www.amazon.com/BAFX-Products-34t5-Bluetooth-Android/dp/B005NLQAHS
Old Aug 3, 2017 | 08:19 PM
db2006's Avatar
Just because there is fuel coming out of the fuel rail valve does not mean the fuel pump is working correctly.
Maybe it has just enough to start, then loses pressure and the engine dies.
You may want to test the pump pressure.
A 2008 in Michigan likely has rusted fuel lines and might be leaking enough fuel so the pressure drops too low when the injectors are using fuel. This engine should have 50 to 60 pounds per square inch.
Old Aug 4, 2017 | 12:22 PM
Could be, but you would think someone would notice the smell of gasoline if not the puddle.
Fuel under pressure has to go somewhere.
Could also be a broken EVAP system or a broken vacuum hose.
But, without codes we could throw money at it all week and not fix it.
Old Aug 4, 2017 | 12:36 PM
And it would be difficult to start if the fuel pressure were leaking down after every shutdown.
Old Aug 4, 2017 | 07:17 PM
  #26
I'm thinking electrical... I had a similar issue this past week while fixing rodent chewed wires.
Old Aug 5, 2017 | 09:24 AM
  #27
M3ndoR's Avatar
I think it has something to do with the air, the signs are simmilar to fuel injectors with air, i dont know how its called in english, i broke my dad car this way, i drove back home and didnt make it to the gas station on time, with Opel Zafira, the infectors ware stuck after they got air, but my dad Opel runs on ON not gasoline.
The symptomes ware simillar after i fueld the car up it was starting worked for 20-30 secons and engine was shuting down
kenny240
Apr 2, 2015 03:32 PM
ruger1v
Jan 9, 2013 04:02 PM
veedub
Oct 11, 2010 07:50 AM
IndyRetroGal
Aug 5, 2008 10:16 AM
AZ RADIO
Jan 2, 2007 04:36 PM
