car would not start :( please help with advice or suggesstions
Old Jan 28, 2011 | 10:42 AM
purity D's Avatar
Unhappy car would not start :( please help with advice or suggesstions
Good morning fellow HHR owners. My 07' would not start this morning, engine would not crank, nothing, it was dead except for the lights on my dash all lit up then turned off. Its as if my battery were dead. On my third attempt and panic setting in, I turned the key and voila, my car started. I bought this car from carmax on Jan. 8th, it has almost 46000miles, purchased it with 45650. I had to take it in two days after purchase because it overheated, they replaced the thermostat and did a proper aligment due to it veering to the right, now this!!!! It sometimes vibrates a bit much (for my taste) at stop lights and at times when coming to a stop I hear a weird knocking noise towards the back of the vehicle or underneath, hard to say where its coming from. Check engine light has NOT come on, no overheating....but what happened this morning has me baffled and very worried. Daughters were late to school and I was late to work!!I tested the car again when i got to work, turned it off pulled they key out of the ignition and waited several minutes to start it up, NO PROBLEMS....I will be taking it in to Carmax for assessment but please, any ideas as to what it may be? I appreciate the help. Dee
Old Jan 28, 2011 | 10:46 AM
ChevyMgr's Avatar
Possible weak battery.
Old Jan 28, 2011 | 10:47 AM
Ditto on the weak battery, I'd start there.
Old Jan 28, 2011 | 11:28 AM
purity D's Avatar
Ok, so I should have them (carmax repair shop) check the battery life?
Thank you for your replies.....
Old Jan 28, 2011 | 12:05 PM
SmootHHR's Avatar
I'd side with Chvymgr. Good place to start. Good luck!
Old Jan 28, 2011 | 12:07 PM
purity D's Avatar
HHR777
Sep 13, 2013 11:23 PM
HillsdaleHHR
Feb 21, 2009 02:26 PM
joeblue
Jan 26, 2009 07:04 PM
Fantumboater
Apr 19, 2008 10:34 AM
lilchapo23jalexy
Jun 13, 2007 06:14 PM
