Climate Control Vent Selector
Old Dec 4, 2024 | 12:07 PM
  #31
The fact that both mode and temp are affected and fuses good leads to wires. Hard to believe ether 2 motors or 2 switches failing at the same time.
Did you check for voltage on both sides of the fuses? Or, just looked at them? Fuse #10 should be hot always #16 should be hot when key on.
Does the rear defogger work?
Do all fan speeds work?
Old Dec 4, 2024 | 01:17 PM
  #32
captneuman's Avatar
Heater
thanks for your help, I actually got everything working again!!! Turns out that when the new stereo was installed I forgot to plug in one of the wire harnesses 🤪🤪 so after checking the fuses and the relay, I said I might need to check the controller itself and found the harness I forgot
thanks again 🙏🙏
Old Dec 4, 2024 | 03:22 PM
  #33
It happens, good news is it’s working!!
Clyde
Jul 26, 2021 04:03 PM
PaperChaseHHR
Oct 8, 2013 04:22 AM
ardblo
Sep 20, 2013 02:03 PM
dustindell
Dec 8, 2010 10:21 AM
Remford
Nov 5, 2009 11:24 AM
