Coolant Leak to start, car won't start
Old Mar 29, 2023 | 04:02 PM
spillthetea10's Avatar
I noticed my car would lag to turn on when trying to start. I noticed coolant was leaking to the starter. I changed the hose that I assumed was the issue. Kept having starting issues, now my car won't turn on & my battery is new. Not sure if the starter went bad & now caused electrical issues. I suppose I'm gonna have to change the starter but can't find where the leak is coming from. Any tips would be greatly appreciated.
Old Mar 29, 2023 | 04:16 PM
greg8453's Avatar
Water leaking on the starter is not going to create your problem. We need to be sure your battery is fully charged and see what you get.
Old Mar 29, 2023 | 04:31 PM
You can bench test the starter.
Old Mar 29, 2023 | 05:15 PM
Year, make and model….So we know what we’re talking about.
Old Mar 29, 2023 | 05:17 PM
Tried jumping the car....wouldn't start. Took off the battery & taking to autozone to charge. Thanks
Old Mar 29, 2023 | 05:18 PM
2008 chevy hhr ss....at this point the car didn't start after trying to jump it. taking battery to autozone
Old Mar 29, 2023 | 05:35 PM
AssUming you followed the directions in the Owner Manual to jump start, why would you think a new/charged battery would help? Isn't jump starting analogous to putting a battery in parallel?
Water runs down or from a pressurized source. the nearest pressurized source is the oil cooler
Old Apr 4, 2023 | 05:50 AM
geg's Avatar
geg
It's not the starter, it's true...
but not only the starter was flooded with antifreeze, a thorough inspection is needed.
If the lambda probe or wiring (including connectors) is flooded, this may be the reason. The generator is far away, but it also does not hurt to check.
Yes, you say it's been a long time, but use a multimeter.
Old Apr 4, 2023 | 12:23 PM
greg8453's Avatar
Been 5 days it should be charged. What is going on?
granman
Jan 4, 2024 06:13 AM
Marc Guay
Feb 16, 2020 02:38 PM
bchappelow
Jan 31, 2019 11:16 PM
Paquinr89
Jul 6, 2016 04:47 PM
Bigjoshg
Drivetrain (Excluding Engine)
12
Oct 22, 2014 04:53 PM
