creak or grinding noise
Hi All
I have a 2006 hhr 190 thousand miles with a grinding or creak noise from spring area , that acts up at low speeds when making a right ( mostly right but on occasion left or straight from a compete stop) I had a mechanic replace the lower control bushings both sides but the same noise returned...
I took the car back, he injected lubricant into control arm area,noise returned a few days later and says he has no idea where to go next for repair..
Has anyone on forum had a similar problem and found a solution repair.thanx for any advice
X3. But at 190k miles that may not be the only noise you have. I would do a complete check of the suspension: front and rear.
FWIW. If your mechanic doesn't know where to look next, you should try another mechanic.
sorry about the mileage error is 120k not 190k
i appreciate the suggestions on top strut mount, that makes sense to me .. Will make a appointment in the morning to have it checked out...
Thanks again for the help...
DeCaff2007
Oct 25, 2014 11:25 PM
mynameistaken
Nov 1, 2010 01:13 PM
