Door Lock Mechanism flaw design 2008
Old Apr 16, 2013 | 02:41 PM
Dan Denton's Avatar
Exclamation Door Lock Mechanism flaw design 2008
2008 HHR door lock mechanism has a design flaw in that it does not allow any manual override to work (i.e. key, door handle, knob) if the motor, linkages, gears, do not pull the tumbler full open or full close. It disables the slot needed for the manual items to work. If your key phob, gear shift leaver or inside door switch does not drive the motor enought or completely you are locked in or out of your car. I have tried oil, grease etc to no avail. I have disabled the drivers door wires to allow me to enter/exit my HHR. If your key phob does not drive 'A' door lock all the way open you are locked out and even a key smith can help. I suggest Chevrolet replace this design. I have never seen were the knob or inside door handle did not override the electric lock system. Denton ME. P.E
Old Apr 16, 2013 | 04:42 PM
Sno White's Avatar
I agree with a lot of what you are saying
I just changed the small motor driving the lock and all is well. My manual lock pull at the top of the door was very difficult, but not impossible to move when the electric door lock did not complete the cycle of interior linkage movement.
The FOB activates the BCM, via the RCDLR, to send out a short duration voltage to the door lock(s). This often is not enough time to fully operate the locking mechanism when it is bad. I proved this to myself by using the electric lock switch on the door. By using the switch and not the FOB I was able to get the door to lock or unlock at will.
Curious, just what are you lubricating?
Old Apr 16, 2013 | 05:06 PM
wmsburghhr's Avatar
Sno White. What you experienced sounds like the problem I am having. What motor did you use and where did you get it. I was thinking I might have to buy the whole lock mechanism. Sure would appreciate a P/n and where to buy.
Old Apr 16, 2013 | 06:37 PM
Sno White's Avatar
PM sent.
I am currently working on a Tutorial including pictures on how to change out the motor. Will post when finished.
Old Apr 16, 2013 | 08:24 PM
Dan Denton's Avatar
My motor just slides in and makes electric contacts. Very (too) simple But it takes three hands to hold and put the total lock assembly together.
Old Apr 16, 2013 | 08:26 PM
Dan Denton's Avatar
any thing that moves. knob shaft, inside the lock assembly, gears, linkages, etc.
Old Apr 16, 2013 | 08:32 PM
Dan Denton's Avatar
the lock assembly acts like a light switch. it has a spring that snaps open or close. But if the motor does not have power or run long enought to pull it worm gear, then the open pie section does not move into a position so the manual linkages mov/slide into that open pie section. Most Electric Lock Systems do not over ride the inside door handle. Even my Toyota with the Blue tooth phob can open the door with the hardware key if the battery is dead so as to open the hood for a jump.
Old Apr 17, 2013 | 03:35 PM
Sno White's Avatar
For repair information see:
https://www.chevyhhr.net/forums/show...045#post701045
Old Apr 17, 2013 | 03:56 PM
bpb355's Avatar
Door lock motor
Nice write up, just for clarification which motor are you suggesting to purchase the fine gear or coarse gear?
Old Apr 17, 2013 | 04:03 PM
Sno White's Avatar
Course
"The important thing is that the motor from the manufacturer DOES NOT have a coarse toothed gear on the shaft. The ebay seller’s did have a course toothed gear making it perfect."
toolbender
Mods - Exterior
38
Mar 15, 2013 09:24 PM
waloupis
Dec 10, 2009 05:53 PM
VictorySpark08
Jan 15, 2009 10:26 AM
Chevy SS
Jun 17, 2008 11:51 PM
TX-HHR
22
Aug 2, 2006 07:19 AM
