Drain problem. Water floods passenger side floor
Old Feb 6, 2024 | 03:13 PM
Babs's Avatar
Took my 2006 HHR to my mechanic. Said problem had to do with sun roof drainage. Said he cleared it and charged me $250. One month later and a rain storm and it flooded again. Now says it may need new drainage channels? This car was garage kept, pristine when I bought it 3 years ago. Help. Thanks.
Old Feb 6, 2024 | 04:02 PM
greg8453's Avatar
Can you run a line down the drains?
Old Feb 6, 2024 | 04:12 PM
Find a mechanic that is not a rip off. If he "fixed" it for $250 he should stand behind his work.
Old Feb 6, 2024 | 04:20 PM
Babs's Avatar
Talked to my mechanic and he said he flooded the drains with a hose. The water is entering near the hump and running off to lower area passenger foot space. He is going to open the cowl and look at the butyl patch some folks were writing about, especially faulty in 2006 model which my car is.
More money cause getting at the patch is work intensive. Thanks for your interest.
Old Feb 6, 2024 | 07:22 PM
Very simple to get to the butyl patch. Take off the wiper arms. Take off the plastic cowl cover. 15 mins. tops.
Old Feb 6, 2024 | 07:42 PM
Babs's Avatar
Yup, that's the next step. Good to know its a 15 minute job. Hopefully he goes easy on the adfitional charge. Thank you. This site is my go to research and help place.
Old Feb 7, 2024 | 07:30 AM
Lonwane's Avatar
If you have ever had your windshield replaced it is possibly damaged/
I took METAL duct tape and covered the hole where the patch was.
Some have used plexiglass or a homemade aluminum panel.
3 years and no water
Old Feb 7, 2024 | 09:54 AM
Double check the door wire harness boots make sure they are installed correctly, and although not rain related clear out the AC pan drain .
raminator01
Oct 1, 2022 07:57 AM
HHR454guy
May 21, 2021 10:34 AM
HHR454guy
Oct 14, 2013 06:13 PM
jonboyb
May 17, 2010 03:53 PM
Dakotarider
Sep 8, 2007 10:51 AM
