Problems/Service/RepairsIf you have a problem with your HHR, want a tip on repairing or performing a particular service to you HHR here is the place to post!
How about the input to the BCM. How would I check that. As for under the hood work, not since I changed the spark plugs, 6 mo. ago. I did not have this issue then.
On one schematic it says that the signal comes from the ECM for L,R and brake. But the others don't show that? I am confused about exactly how the signal works.
Donbrew, Thanx again for all the help. I noticed that in all of my previous posts that I forgot to mention that my front drivers side turn signal works. Is it possible that the load resistor caused a weak solder connection in the BCM to undue. As for being confused, so am I, but I will not stop until this mystery is solved. In a DC circuit electricity only flows one way.
Here's the latest. Battery lobotomy, no change. Multi purpose switch replaced, ACDelco unit, no change. Removed waterfall and various trim and traced power going into BCM but no power out of BCM. ALL testing done with 12v test light. Next will be the BCM but Midway Chevrolet quoted $220 to flash new one.
With the ignition off I removed the X3 connector and turned on the emergency flashers. I touched the A9 pin on the BCM with a 12v test light. No light. I then touched the A12 pin and got a flashing light. I'm not sure how to access the other side of the pin.
