Elec Window Stopped Working
Old Oct 11, 2012 | 10:01 AM
jaymz's Avatar
2008 SS: driver's side rear window stopped working recently. Haven't looked at it yet, but any hints/clues/guesses what might be wrong? All other windows work fine.
Jim
Old Oct 11, 2012 | 11:22 AM
foxtrotraptor's Avatar
I have a 2008 SS, same thing happened to me rear window as well. Took it to the dealer they said it was the "window regulator" , Luckily I got a extended warranty so I only paid 50. total cost for repair according to my local dealer is 280 parts and labor. hope this helps
Jim
Old Oct 11, 2012 | 12:03 PM
BlackknighT's Avatar
Any noise at all from the motor? Clicking noise (arching of sparks) at the regulator when you rock the power switch up & down? Old fashioned way of checking for "dead spots" on the stator/regulator was to slap the door panel while pushing the switch up & down. If its the regulator the slapping/banging of the door panel might move the regulator enough combined with the internal arcing of the DC current might make the motor work for a short time. Also narrows down if its the switch or not. Never close your windows completely tight-holding the switch up or down till the window is "extra closed" creates bad/dead spots on the motor.
Old Oct 11, 2012 | 05:13 PM
would have to havee the car to diagnose
Old Oct 11, 2012 | 05:25 PM
07azhhr's Avatar
Originally Posted by BlackknighT
Any noise at all from the motor? Clicking noise (arching of sparks) at the regulator when you rock the power switch up & down? Old fashioned way of checking for "dead spots" on the stator/regulator was to slap the door panel while pushing the switch up & down. If its the regulator the slapping/banging of the door panel might move the regulator enough combined with the internal arcing of the DC current might make the motor work for a short time. Also narrows down if its the switch or not. .
^^^This^^^
skates
Jan 1, 2015 09:47 AM
acablexi
Nov 19, 2010 09:57 PM
Ambivalence
Jul 8, 2010 12:59 PM
SIHHR
Dec 6, 2008 02:59 PM
Kicker|MyU
Sep 19, 2008 08:00 PM
