A/C stopped working any ideas!!!
Old Nov 18, 2010 | 10:49 PM
acablexi's Avatar
Unhappy A/C stopped working any ideas!!!
I just noticed today that my A/C doesn’t work for my 06 HRR! (great )
And It only works when i blast the air to the max...
Has anyone had this issue????? and if yes, any suggestions???
went through the site and couldn't find any similar issues like mine
Old Nov 18, 2010 | 11:22 PM
Sounds like its low on charge, that's the first thing I'd have checked.
Old Nov 18, 2010 | 11:45 PM
Go to the auto Parts & get a can of A/C "Leak Detector" & the rig to install it.
(edit): Run it a while & then in a low light area, using a Black Light the leak will glow like neon yellowish green..
Pay close attention to fitting connections, the Condenser in front of Rad, & around the A/C housing.
Fix the leak..or have it repaired & properly re-charged
Old Nov 19, 2010 | 12:09 AM
1Panel2NV's Avatar
The refrigerant already has that in it. A neon green color like you said.
The op might be talking about the fan...they weren't specific as to whether the fan wasn't working or the ac wasn't cooling.
Old Nov 19, 2010 | 01:02 AM
IgottaWoody's Avatar
Wait..missing something here..he says it only works when he BLASTS the air.....so, your saying the air doesnt work on the lower settings? Or that it doesnt get cold unless its on high air? Low freon doesnt care what the fan speed is...t would actually work better at slow speed as it has time to cool the air.....this could also be air restriction ,, ie- filter...or a fan swt resistor.....just clarifying
Old Nov 19, 2010 | 01:13 AM
Yeah, on second and third thoughts, it might be a blocked cabin air filter or hung blend door. But I have had units with weak charges that only got cold when you blast them at maximum settings, although we are talking Corvairs here(prehistoric at best).
Old Nov 19, 2010 | 06:28 AM
pitbull76's Avatar
acablexi, Is it the fan or the A/C that doesn't work at the lower settings?
If the fan only blows on high, the blower resistor is shot. If this is the case, look at the cabin air filter and see if there is evidence of water getting in. If there is, you will have to repair that as well or your blower motor and/or resistor will just fail again.
If the A/C is just working poorly, then it may be low on refrigerantg or as others suggested possibly a blend door issue or something like that.
Old Nov 19, 2010 | 09:20 PM
acablexi's Avatar
there is no air at all coming out in any of the setting only in max... and when it does blow air in max it is cold.
i normal hear the fan when i turn it on but now nothing!
Old Nov 19, 2010 | 09:31 PM
Thats the blower resistor pack not allowing your slower speeds..... needs replaced.
Old Nov 19, 2010 | 09:57 PM
acablexi's Avatar
i have been reading other threads and it sounds like i need to buy the blower resistor for my car... am going to check it it tomorrow, so i'll see how it goes...
am wondering if am going to need the whole package deal? i have 111,000 miles on my car so i dont really want to take it to the dealer
skates
Jan 1, 2015 09:47 AM
jaymz
Oct 11, 2012 05:25 PM
Ambivalence
Jul 8, 2010 12:59 PM
SIHHR
Dec 6, 2008 02:59 PM
Kicker|MyU
Sep 19, 2008 08:00 PM
