Engine swap
Old Mar 15, 2019 | 09:18 PM
Communications between the modules is on the CANBUS not the wiring. I don't know what else you may have done.
The TCM connectors appear to be the same 2007-2009.
Old Mar 16, 2019 | 11:37 AM
Tim Coole's Avatar
True that about the can bus but wouldn't the data wires have to land on the same points between the two years does that make sense
Old Mar 16, 2019 | 12:14 PM
Check your Private Messages.
"Not communicating" does not mean "Not connected" on a network. The modules need to be aware of each other, then hand shake etc.
Old Mar 16, 2019 | 02:55 PM
Tim Coole's Avatar
Thank u very much Don brew I am sure that will help immensely
Old Mar 16, 2019 | 09:21 PM
guppy's Avatar
Tim, This is a most interesting task that you have taken on. so what did you do back in 2017 to get it to start, think you were talking about a vector package? This is way over my head, but I always wondered the same.
Old Mar 17, 2019 | 07:10 AM
  #26
Tim Coole's Avatar
Yes I went with the vector package Alex did a great job just had to jump the pnp switch and she fired up now I think I shorted the TCM because it is giving me a TCM not communicating but it has been two years since I tried anything so don't recall If that fault was there since it did not start when I tried and was told I couldn't do it I gave up and just looked at it again and saw how to start it so here I am
Horazz
Feb 6, 2023 12:24 PM
DBHHRLT
2.4L Performance Tech
Oct 20, 2014 05:41 AM
RF2
Jan 12, 2014 08:36 PM
skuzzlebutt
Nov 3, 2013 09:58 AM
xzombie
Sep 1, 2009 02:18 PM
