Engine Or Transmission
Old Jun 20, 2017 | 07:35 PM
Originally Posted by chessplayer41
Well, I have taken it to a regular mechanic with no affiliation and talked to another ex Chevy mechanic and both are perplexed as to what this car is doing. No one can say for sure if it's the engine or the tranny. We did confirm that there is a leak at the flex pipe as OldBlue mentioned. If that's the culprit then I'm not understanding how exhaust could cause this issue regardless of the car being hot or cold. SO...looks like I will have to do what I have been dreading all along, take it in to the dealership and see how much they are going to hit me for just to tell me what's wrong with it... Until then I'm still up for suggestions.
Why do you need someone else to tell you what's wrong? A broken flexpipe can cause all kinds of problems. It allows metered air to escape, it allows unmetered air to enter. This confuses the computer, causing the engine to fluctuate between rich and lean conditions.
Old Jun 20, 2017 | 08:06 PM
Why not fix the part that is endangering your life and hope a bunch of internet bozos are right?
Old Jun 20, 2017 | 08:29 PM
Old Jun 21, 2017 | 09:56 AM
Bozo
Or Krusty
Old Jun 21, 2017 | 10:25 PM
chessplayer41's Avatar
Full circle...Started out with the exhaust and ended with the exhaust. A few small crack along the inside of the flex pipe was causing all this mess. Sealed the hole and now I'm back on the high way...just like that. All that money and in the end all I needed was about $2 worth of Muffler Weld paste place on the inside around the edges. Thanks to you all for the great advice. Looks like a have a new favorite forum...as long as I have my HHR.
Old Jun 21, 2017 | 11:28 PM
  #26
FYI. That weld paste won't last. It's a flex pipe and thus flexes under torque from the engine. Weld paste doesn't flex.
Plan on replacing the flex pipe in the near future.
Old Jun 22, 2017 | 08:00 AM
  #27
You're gonna need at least one of these
But get it welded in!
Here's a how to
https://www.chevyhhr.net/forums/how-...ex-pipe-31536/
Old Jun 25, 2017 | 08:54 AM
  #28
Yes the paste is only a temp fix so that I am able to go and get a new exhaust and CAT for $350. It still feels good going from a max of maybe 60 at full throttle to 75 coasting. Amazing how much a small exhaust leak can effect the performance.
Old Jun 25, 2017 | 10:17 AM
  #29
OK, we have proven we are right once, why not accept the second idea and save yourself $250?
Old Jun 25, 2017 | 11:29 AM
  #30
Because , just because! Some shops will only install their parts they procure and sell.
geg
2.4L Performance Tech
Jun 22, 2021 11:13 AM
jrich
Feb 20, 2015 05:04 AM
bpb355
Drivetrain (Excluding Engine)
Jun 18, 2014 06:32 AM
menance
Dec 22, 2010 06:14 PM
