Fuel Line
Old Nov 27, 2019 | 11:01 AM
I did on the 2011, in October
https://www.chevyhhr.net/forums/how-...follies-62310/
this is the kit , I used for your 2007 HHR
https://rover.ebay.com/rover/0/0/0?m...2F182759213082
Old Nov 27, 2019 | 12:35 PM
fastsuv's Avatar
I ordered the nylon kit that goes from tank to mid-section.
Oldblue, did you buy new heat wrap and wrap the lines where they were wrapped from the factory?
Steve
Old Nov 28, 2019 | 06:15 AM
I re used some of the old insulation after letting it dry in the sun
Old Dec 22, 2019 | 12:10 PM
tomdel50's Avatar
fuel line
i have a 2077 hhr LS. what type of fitting it there on the hose from the tank to the metal gas hose is it a typr of clip or do i need a tool
Old Dec 22, 2019 | 02:33 PM
From the how-to area: https://www.chevyhhr.net/forums/how-...service-26442/
Old Dec 22, 2019 | 03:26 PM
As the directions show blow the fitting clear with compressed air if you have it and a squirt of WD 40 to lube it oring , then you can separate the bundy fitting, For that you squeeze the D shaped fitting gentle with a pair or pliers and gently pull and twist the metal line out.
Be Careful here double check the new metal line to ensure there is no burr which will destroy the oring!
Oldblue
"How To" Tutorial Library
123
Mar 16, 2025 09:35 AM
QuickDrawMcGraw
GM Recall Campaigns
25
May 9, 2019 09:48 PM
budzone
May 16, 2018 10:30 PM
Leroy Cook
Maintenance and Upkeep
7
Apr 2, 2018 09:57 PM
Grizzly old man
28
Nov 13, 2015 12:16 AM
