Fuel pressure sensor
Old Feb 21, 2023 | 11:20 AM
StormHHR925's Avatar
Thumbs up Fuel pressure sensor
Where is the location to the fuel pressure sensor in a 2010 Chevy HHR 2.2 l LS
Old Feb 21, 2023 | 11:24 AM
2010 Chevy HHR 2.2 ls
Old Feb 21, 2023 | 11:29 AM
The fuel pump module consists of the following major components: • The fill limit vent valve • The fuel level sensor (3) • The fuel tank pressure (FTP) sensor (1) • The fuel pump • The fuel strainer • The fuel pressure regulator (2)
Old Feb 21, 2023 | 11:31 AM
How do I get to it is it to the inside of the car or underneath the car
Old Feb 21, 2023 | 11:34 AM
You have to drop the fuel tank, might as well change the fuel pump assembly at that point
Old Feb 21, 2023 | 12:12 PM
Why not tell us what kind of problem you are experiencing. We can then let you know if you are chasing the correct fix.
Old Feb 21, 2023 | 01:30 PM
greg8453's Avatar
What makes you think you have a fuel pressure problem? Gut feeling or did you test something.
Old Feb 22, 2023 | 09:45 AM
PulpFriction's Avatar
I don't think there is a fuel pressure sensor. The fuel pressure regulator on the fuel pump is probably just a pressure relief valve, IDK.
You can check the fuel pressure at the schrader valve on the fuel rail. 55-60 psi, should hold pressure for several minutes after shutoff. Read up so you don't burn your car down.
Ditto on explaining the problem you're having.
Old Feb 22, 2023 | 10:59 AM
The fuel tank pressure sensor is what I pointed out, as for fuel pressure it’s tested as mentioned at the schrader valve on the fuel rail
chevcat
13
Jun 8, 2023 06:48 PM
ColonelStinkmeaner
Oct 19, 2021 05:12 AM
Lonwane
Sep 2, 2020 02:30 PM
car nut
Dec 3, 2013 06:32 PM
Paina
Jun 28, 2013 04:49 PM
