Fuel Tank 20866941 - Vent line issue - looking for new replacement
Old Oct 11, 2024 | 12:15 AM
BERNS's Avatar
Hello All,
Been a while since my last post but I have been getting the fuel smell in the cabin and around vehicle when filled up. Gotten to the point that I calculate the gallons it takes without having to fill all the way to avoid smell.
I am located in the High Desert of California and my 07 HHR 2.2L LS has always been a Cali car so there is no rust including the fuel and vapor lines. Checked and no signs of any pin holes.
I have read posts about the same issue but have yet to get an answer to my question.
Has anyone bought a new tank from GM. Part no. 20866941 and does it come with the new vent lines? GM Parts Direct Customer Service was not able to confirm.
This is my last resort and I really love this car and would like to keep it running. Other than this nuisance, it runs perfect.
Old Oct 11, 2024 | 07:31 AM
The GM part number is for the tank and adhered lines, so, vent lines , not fuel or return lines.
Old Oct 11, 2024 | 07:46 PM
BERNS's Avatar
Thanks for confirming. Seems I will have to replace cause I have yet to read a post with an adhesive that can withstand fuel and looking for a more permanent fix.
A bit pricey but I would rather avoid the complications that fuel vapors can bring.
Appreciate the help!
Old Oct 12, 2024 | 07:36 AM
Perhaps a tank from a pick a part yard?
Old Oct 12, 2024 | 08:30 AM
Maybe I didn’t see it but where do you say that it’s confirmed that the tank is leaking. Or are you just assuming it is ?
Old Oct 16, 2024 | 11:16 PM
BERNS's Avatar
Went through the whole car, lines, evap system and no leaks or rust. Happened to have the car on ramps inspecting the charcoal canister and I happened to squeeze the fuel filler hose to the tank a few times and the smell seemed to be coming from on top of the tank. Surrounded car and cabin, pretty strong. When I am under the full mark, the smell goes away.
I am simply confirming part number in case my shop states the yellow vent lines are toast as I do not think there is an adhesive that will resist fuel long term.
Trying to keep it running. Body and interior are in great shape, runs smooth and at 160K, I think it has lots of life left over. Plus I love that it is no frills car, no power seats, no ABS or anything that would cost a fortune to replace. Can't complain, got the car about 10 yrs ago for $1k and has served me well as a daily driver when I used to drive into work.
Old Oct 17, 2024 | 07:09 AM
Replace the filler neck hose and take a closer look at the filler pipe for holes
chuckbear
Dec 11, 2024 11:29 AM
unknwn
Jul 18, 2024 06:50 AM
McB_HHR
Sep 4, 2022 09:25 AM
JonArcherAZ
May 4, 2022 07:10 AM
DangerBoy
Apr 18, 2022 05:38 PM
