Gas smell
Old Dec 23, 2017 | 08:41 AM
You are not dead, yet.
You are aware that gasoline fumes are explosive?
Old Dec 23, 2017 | 08:43 AM
It sounds like an issue with a connection that is not under pressure, perhaps at the EVAP canister or the over fill tube.
Disconnect, inspect each fitting , there would be 3.
Old Dec 28, 2017 | 10:22 AM
aradmahogany's Avatar
Does it smell like gas even when you get home after a drive or just on a cold start?
Old Dec 31, 2017 | 05:15 PM
Tompcomp's Avatar
Shop found leak in plastic line.
I had a gas smell and vapor leak code.
my shop found a leak in a plastic line above the fuel tank and fixed it with some plastic weld.
Old Dec 31, 2017 | 05:26 PM
These lines from the pump to the metal lines
Old Jan 17, 2018 | 03:02 PM
Liquidh8's Avatar
Funny I saw this, as I am also getting a bad gas smell from the DS rear tire area. Going to throw it up on the lift tonight and see what I can find. It's going to be difficult though since there is snow on the ground and the bottom of the car is most likely all wet.
Old Jan 18, 2018 | 06:51 AM
Thats where the tailpipe is so..... do you only smell it when first starting the car or is it still there even after the car is fully warmed up.
Old Jan 18, 2018 | 08:01 AM
Actually the fuel lines do go from the rear of the fuel tank out to the rear then across to the drivers side then forward to the engine bay. Maybe there’s a leaky pipe, look at any of the retainer clips for corrosion
pdmorris1
Feb 15, 2016 01:58 PM
miles solo
Dec 31, 2013 10:22 AM
bigjacksauto
Apr 9, 2012 05:05 PM
bartSS
Mar 12, 2011 11:42 AM
JazzDad
May 25, 2010 11:03 AM
