Had bluetooth and now none
Old Mar 23, 2018 | 01:03 PM
Cat Man HHR's Avatar
Always glad to help when I can.
Old Apr 30, 2019 | 12:28 PM
Lost connection between phone and Bluetooth
As the title says. Had the phone in the car and received a call but Bluetooth didn't function.
When I got home I went thru the steps to pair my phone by first deleting the phone from the car.
Turn key on and pressed the speak button but the system didn't say "ready".
Held the speak button down while waiting for response (no good) and held it down for 2 seconds and let up to see if that mattered, samething.
I paired with the car successfully with this phone 2 years ago with no problem.
Tried Google but no luck in finding the answer.
Old Apr 30, 2019 | 01:05 PM
Didn't you have this problem before ? If so, what was the fix back then ?
Disregard if I'm thinking of someone else.
Old Apr 30, 2019 | 01:21 PM
That was someone else.
But I found the problem or the fix I should say.
Delete your phone from car system.
Pull the 50 amp maxi fuse by the battery and plug it back in to reboot the BCM (Body Control Module) .
Now when you hit the speak button you hear "ready".
Then do all the steps to pair phone to car.
When all done reset the clock time and date on radio. No stations will be lost.
Old Apr 30, 2019 | 01:29 PM
This is why I thought you had the problem before:
https://www.chevyhhr.net/forums/prob...ow-none-60108/
Old Apr 30, 2019 | 01:39 PM
Merging the two threads would keep the two solutions together for ease of finding later.
Old Apr 30, 2019 | 01:48 PM
George is correct and I had totally forgot that I had made the first one. Forgive me.
I don't know why I had to do this twice though.
First time might have been before I changed the battery ?
It's nice to know you can reset it from two locations. The 50 amp fuse in the back or the #24 fuse in the car.
Thanks again for your help Richie. It worked out just fine.
Old Apr 30, 2019 | 04:07 PM
Merged
I thought it sounded similar. But turns out identical, I think all of the original words match up.
Old Apr 30, 2019 | 05:46 PM
Originally Posted by donbrew
Merged
I bet it was the same person too.
finnhhr
Mar 17, 2018 10:50 PM
Rikki Sixx
Apr 20, 2017 05:23 PM
oldracer
Apr 30, 2013 11:20 PM
SS HHR CDN
Dec 24, 2008 08:03 AM
cj krause
Aug 30, 2006 11:10 PM
