Had a CEL pop on this morning on the way to work.
Old Apr 24, 2013 | 06:47 AM
solman98's Avatar
Well, coming home from work yesterday, the light went off. Got me to thinking, I refueled the day before it came on. I refueled 2 days before it went back off. Makes me wonder. Still planning on taking a close look at things my next oil change, which won't be too long now. Unfortunately, I already ordered both O2's. Well, I'm at 91K already, even if it's "fixed" itself, will still need them sooner or later.
Old Apr 24, 2013 | 08:13 AM
cj krause's Avatar
you could always do a tune on it, do a rear 02 sensor delete and then take it off and hammer out the guts or find a shop that will cut off the cat and weld back on a hollowed or cat w a straight pipe thru it
leave the sensor on and with the rear 02 delete it wont matter
i did this on my 06 a long time ago
you can get 02 sensors at most all auto stores for around $20 each
Old Apr 24, 2013 | 09:45 AM
solman98's Avatar
I've got O2's coming from RockAuto. Won't gut the cat, today's cats flow very well, there is no need to gut or remove. Plus Atanta requires testing.
Old Apr 24, 2013 | 09:55 AM
cj krause's Avatar
if sniffer testing is required that is different
we test in TX but use obII port and the tune takes care of that
just looked man they are high
i kept my old ones off the 06 and other engine in case i need them
Old Apr 24, 2013 | 10:13 AM
solman98's Avatar
I got both for about $70 shipped. They had cheaper ones, but I want to make sure I get plugs and not universal ones.
Old May 20, 2013 | 03:55 PM
solman98's Avatar
Well, the light came back on again the other day. Had it scanned today, same PO420 code. So that to me sounds more like the O2 than the cat. Will be changing the oil very soon, so I will take care of this at the same time.
Old May 20, 2013 | 04:15 PM
jay loukakis's Avatar
When my fle-pipe started a lot oh xhast fumes in the car, bought the flex-pipe from rock-auto $49.00 including shippinf, had it replaced at Mids cost me $90.00 its fine now. good luck.
Old May 22, 2013 | 01:37 PM
solman98's Avatar
No smells, fumes, or odd noises.
Old May 24, 2013 | 08:25 PM
Don06's Avatar
Isn't that code for an oxygen sensor on the converter reading below threshold? It might just need an oxygen sensor.
Jeffharden1
Aug 25, 2014 01:50 PM
Jeff®
Mar 28, 2012 10:21 AM
stephenm
Apr 8, 2009 07:24 PM
stick
Jan 24, 2008 05:13 AM
Dirtsurfer
Jan 20, 2008 10:49 PM
