Heater core valve/hose, fluid loss
Old Jan 19, 2018 | 08:29 AM
A two piece housing , this one, an aftermarket, touts it has a composite impeller
The AC Delco water pump comes complete with drive sprocket and gaskets, as seen in these pictures in this ad
https://www.ebay.com/p/Engine-Water-...-751/227257567
And this from RockAuto
http://www.rockauto.com/en/catalog/chevrolet
Old Jan 19, 2018 | 11:58 AM
Cat Man HHR's Avatar
Originally Posted by whopper
I don't know if I would recommend a flush prior to refilling or not - it might be the kiss of death to the rad or heater... maybe
I was thinking more of the freeze out/expansion plugs.
Old Jan 19, 2018 | 12:17 PM
Originally Posted by Oldblue
Don, that impeller looks like it’s not aluminum!
A 2009, would be 9 years old now and I’m seeing signs of neglect, in that corrosion in the system, that indicates, at one point, someone put
A , just water to top up the rad, throwing out the 50/50 mix.
B , hasn’t changed out the Dexcool for Dexcool.
C , poured in the green stuff.
A- Looks like a lot of "junk" water vs anti-freeze. Rule of thumb, if you can drink it put it in the cooling system.
B- There was none
C- That is a possibility, mixing the two types would cause a possible jelling but would give you corrosion protection which the system didn't have.
D- Brown coolant can also be from bad grounds to the engine and radiator plus not being serviced since day one.
Old Jan 19, 2018 | 01:21 PM
Yeah, that too - they can't be in the best of shape either. And I wonder about the "mechanic" working on it - did you notice the broken off boss on the housing? That must have involved levering it off and breaking the housing?
voigtsga
Jul 20, 2015 06:26 AM
glidewell77
Jun 24, 2014 12:41 PM
foolmoon_design
Dec 14, 2009 07:10 PM
hhrbast
Dec 10, 2009 06:24 PM
jonboyb
Apr 23, 2009 12:52 PM
