HHR overheating
Old Aug 13, 2017 | 10:20 PM
Originally Posted by shoemaro
Ok, replaced radiator and lower hose, filled with DEXCOOL, took the thermostat out, but i don't notice the coolant flowing. I replaced the water pump, has anyone ever had a pump with bad flow or just doesn't work well? with the thermostat out, coolant never looks like it is flowing and it slowly overflows out the filler neck.
Well, since it's overflowing, you know it's flowing. The filler neck is not the highest point of the cooling system. You need to burp the system. See my prior post.
Old Aug 14, 2017 | 09:29 AM
The overflow is caused by heat expansion, otherwise there would be no pressure.
The HHR has a odd cooling system, Us old folks are used to looking at an expansion tank and seeing a flow. That doesn't happen in the HHR, it does not flow when not under pressure.
The coolant is "sucked" out of the radiator through the lower hose, older engines it was "pushed" into the upper hose.
I worried about it, too. Yes there have been faulty water pumps.
My experience was a tiny crack in the cap on the t-stat housing was letting steam out, but it was not enough to leave evidence.
Old Aug 15, 2017 | 11:13 PM
shoemaro's Avatar
Well i noticed something interesting as I am monitoring the overflow bottle. I drove the car 20 min or so, then opened the hood and noticed the coolant was bubbling out of the overflow bottle vent hole or overfill hole. Then let it cool off and the coolant went back down to the normal level. Is that a sign of a bad head gasket?
Old Aug 15, 2017 | 11:30 PM
Here is a link to show the proper "cold" level of the recovery tank.
https://www.chevyhhr.net/forums/main...ank-pic-55772/
If the coolant level is as shown when cold, and overflows after 20 minutes, you certainly have a problem. A compression test should help diagnose a bad head gasket. If you don't have one, your local auto parts store should have a 'loaner' program.
Old Aug 16, 2017 | 06:40 AM
Overflow can also indicate a bad rad filler cap.
Old Aug 16, 2017 | 09:21 AM
Over filling the bottle is bad. Coolant is supposed to go back and forth, however excessive amounts indicates exhaust gas pushing it out.
Old Aug 16, 2017 | 09:44 AM
And if the cap is weak and won't hold 15 psi then it'll allow Dexcool past it! Here
Attached Thumbnails HHR overheating-img_0676.jpg   HHR overheating-img_0675.jpg
cmelvin531
Oct 27, 2018 04:43 PM
vapinhhr707
Dec 17, 2014 02:21 AM
raccoonjoe
May 18, 2014 10:59 PM
Kylo
Aug 16, 2013 09:28 PM
et7333
Jun 8, 2012 03:10 PM
