HHR rejected by emissions station
Old Feb 10, 2022 | 03:44 PM
You scroll through the DIC using the buttons on the left side of the steering wheel, the second from the bottom.
Old Feb 10, 2022 | 05:45 PM
CP_HHR's Avatar
Originally Posted by donbrew
Since you ignored my first question I will risk answering yours and ask again; what specific test is not ready; it makes a difference how long it takes..
A free digital Owner Manual is available via the link in my sig.
I don't know.
Old Feb 10, 2022 | 06:21 PM
CP_HHR's Avatar
This is what they gave me. I removed the tag and VIN numbers.
Old Feb 10, 2022 | 06:27 PM
CP_HHR's Avatar
Originally Posted by fastsuv
I forgot to mention, if it says SVC tire monitor, it means there is a problem with the monitoring system (battery dead in tire unit, receiver bad, etc). If a tire is low a different message is displayed, "check tire pressure" (I think).
In any case, scroll through the DIC displays until you see the tire pressures for the 4 tires. If there are any dashes instead of a reading, that sending unit is not working. If all are dashes, that could mean a bad receiver or all 4 sending units are bad( dead battery usually).
I saw a battery in the back one time when I was looking around in the HHR. It looks like a typical car battery and thought it got recharged automatically along with the battery under the hood. Is that true or do I have to recharge that with a recharger? Why would it be dead?
Old Feb 10, 2022 | 06:50 PM
That battery in the back is "the battery"... there is none under the hood.
Old Feb 10, 2022 | 07:12 PM
What you thought was a battery up under the hood, it’s the fuse box
Old Feb 10, 2022 | 07:16 PM
CP_HHR's Avatar
What about the battery in the tire monitor unit?
Old Feb 10, 2022 | 07:22 PM
CP_HHR's Avatar
Beltsville self serve kiosk not working
http://bikearlingtonforum.com/showthread.php?19086-Beltsville-self-serve-kiosk-not-working&
Old Feb 10, 2022 | 08:47 PM
That receipt does not say anything about failing. Go to your local big box auto parts store and ask them to read your OBD2, then tell us what the codes are, we don't care what is "says". The codes will tell what is wrong and be sure to ask for I/M Readiness (that will tell what test is not run).
Why do I care if the Beltsville Self serve kiosk is not working?
Now we know you are in Maryland .
Once again a link in my sig leads to a free Owner Manual.
DOWN HERE
V
Old Feb 10, 2022 | 09:25 PM
fastsuv's Avatar
Each tire has a small pressure sensor inside the tire attached to the tire valve stem. This sensor has a built-in small battery (like a watch battery size) that usually lasts around 8-10 years. This battery itself cannot be replaced, the whole sensor must be replaced.
Steve
