High beam problem
Old Aug 18, 2010 | 08:58 AM
Gas Man's Avatar
Originally Posted by Lee3333
That is my next step. CJ from the other forum suggested the same-check connections in socket. It is just a pain since the wires are not very long and I don't want to remove the tire.
You should be able to remove the first bolt and the 2 lower push pins to gain access to the headlight wiring withOUT removing the tire... you will scrape up your arms but still.
Old Aug 23, 2010 | 09:58 AM
Lee3333's Avatar
I did but there isn't much slack on the wire-it barely sticks out of the fenderwell. But I should be able to work with it, when the rain finally subsides.
royperry
Jan 26, 2019 08:13 AM
Knightrider03m
May 6, 2014 09:42 PM
1BadPig
Mods - Exterior
10
Jul 29, 2009 06:17 PM
TrekMadone5.2
Dec 27, 2007 08:03 PM
