Horn inop
Old Mar 2, 2024 | 08:02 PM
Mookie1's Avatar
Horn inop
Hello all
So Inherited a 2008 and the horn is inop. Checked the fuse ok there is power at the relay but when you push the steering wheel horn nothing. I checked the output from the horn button at the relay and nothing. Should have a ground contact to close the relay and nothing is there any known bad connections before the relay. I tried to find a replacement horn switch and it is discontinued. Any ideas.
Thanks
Old Mar 2, 2024 | 09:05 PM
Do the other buttons on the steering wheel work? If not the clock spring is broken.
Has anyone been monkeying around under the airbag?
The switch is just a piece of metal that makes contact with ground.
Have you tried hot wiring the horn to be sure it works?
Old Mar 3, 2024 | 07:33 AM
Mookie1's Avatar
Yes the other buttons on the steering wheel work. I need pin out the relay and when you push the horn button it doesn’t ground the relay to power the horn.
Old Mar 3, 2024 | 07:56 AM
Here is the wiring. You can get through the link to FREE shop manuals in my sig, also.
horn.pdf
how about grounding the relay?
Old Mar 6, 2024 | 07:59 PM
Mookie1's Avatar
Fixed it found broken wire going to the horn. Thanks for the wiring info.
Doog47
Jun 14, 2012 12:13 PM
allman
Jul 30, 2010 01:30 AM
Ambivalence
Jun 8, 2010 05:33 PM
Scrivs
Jun 19, 2009 01:27 PM
dinobass
Dec 30, 2007 10:59 PM
