Howling/grinding noise
I have the same problem with my front end making a grinding noise. The noise is more noticeable from the drivers seat than the passengers and gets MUCH worse when curving or turning to the right.
I too thought it sounded like a tire rubbing on something but it's not. If anyone has figured out exactly what that noise is I would sure appreciate knowing so that when I take mine in I can at least make some sounds like I know something
Yes, many people have found what the problem is. The search tool will return an abundance of threads related.
Usually it is a hub/bearing, sometimes it is the flex joint on the exhaust. Try some of those search terms.
If it's "grinding" - it needs to be attended to quick - that can be a dangerous problem if neglected. Let us know the progress if you can.
my 2007 started making a noise like the one described, I too tried to isolate it left or right, with car on jack stands and in gear and also when driving the noise does not start util about 25 mph or higher and it gets louder the faster you go, and it's not engine speed dependent but wheel speed. the hubs seem ok, the tires have normal wear, the brakes are fairly new. with the hood open the noise almost seems to be coming from the center behind the engine. is there an intermediate shaft that comes out of the trans to drive the right side axle? or some kind of bearing in that area that could be going bad?
Best thing to do is start a new thread and describe what is going on in your case.
For one thing FlatHHROwner seems to have been driving his car while having his head in the engine compartment. But he was describing a cracked flex pipe, nothing to do with suspension.
So, I seriously doubt your case is exactly the same!
badassbowtie
Jan 2, 2024 09:35 PM
DeCaff2007
Oct 25, 2014 11:25 PM
mynameistaken
Nov 1, 2010 01:13 PM
