I知 lost again, many codes
Solved for now I guess
I tested the resistance through pin 6 and 14 while unplugging and plugging all the electronics. I was getting the normal 60 and 120 ohm readings.
I inspected:
EBCM connector
TCM connector
ECU 3 connectors
BCM 2 connectors
Pushed in all the fuses and relays under hood.
all the pins on the connectors looked good and the wires looked ok where they protrude from their sleeves. I think that replugging things that haven稚 been touched in 14 years fixed it, no symptoms returning yet. Fingers crossed
I inspected:
EBCM connector
TCM connector
ECU 3 connectors
BCM 2 connectors
Garyroe75
May 24, 2022 09:03 AM
findmyhome
May 22, 2019 03:49 PM
